1 - 2 of 2 Posts
2011 Honda Fury
I found an item called the Speedo Healer (link below). It says it's for a Fury. Has anyone installed one? If so, does it bypass the speed limiter? I know the chasis wasn't designed for higher speeds, but there are times I'd like to maybe get an extra 5-10 MPH out of it. Let me know if you've tried it and what you thought. Thanks.
Never tried it but, if it works the way you think, it would cause your speedometer to be wrong at all speeds in order for it to accomplish what you are wanting.
The ECU reflash is a better alternative IMHO.
I personally don't think it would accomplish what you are wanting because the ECU isn't speed restricted, it is RPM restricted.
5250 rpm in 1st, 2nd, 3rd gears.
5000 rpm in 4th gear = 100 mph
4800 rpm in 5th gear = 100 mph
1 - 2 of 2 Posts
