If you suspect your speedometer is inaccurate keep reading. If not you can ignore this thread.
I have found that when I travel what I think is the speed limit; I am being passed on a regular basis with not so friendly gestures by some as they overtake me. This problem may be limited to me, as I have not seen anyone else on the forum complaining.
While I suspected a problem, I didn’t know for sure until I travelled with my Garmin Zumo 550 GPS. My speedometer at 100kmh (66mph) was reading approximately 8kmh (5mph) faster than my actual road speed as verified by the GPS. While this may be fairly minor, it was also adding mileage to the bike faster, giving inaccurate fuel consumption measurements and generally was irritating.
Apparently, manufacturers are allowed a variance of up to 10% for speedometer readings. Research showed that inaccurate readings are not uncommon as many things can affect this, such as over or undersize tires, changing sprockets on chain drives as well as inaccuracy of the speedometer. Personally I think the manufactures have the technology to insure the speedo is accurate. My conspiracy theory is that the manufacturer makes them read slow under the auspice of safety when actually it is part of planned obsolecense as the miles rack up faster when the reading is slow.
A few devices exist to correct the problem and also prove useful for correcting speedometers that are out due to sprocket and tire size changes.
So the two products I reviewed were:
Speedohealer by Healtech Electronics - HealTech Electronics Ltd. - Makers of the SpeedoHealer, GIpro, X-TRE, FI Tuner Pro, Brake Light Pro, MM5, OBD Tool
SpeedoDRD by 12 OClock Labs - SpeedoDRD
I wanted a plug and play solution as I did not want to cut any wires. I was leaning to the Speedohealer but fitment on their website indicated the Fury model was the universal harness kit model SH-U01 which required splicing.
My brother in law corrected his VTX1300 with the version from 12 OClock Labs which was plug and play. Unfortunately the VTX version is not compatible with our VT1300's. I contacted 12 OClock Labs via e-mail inquiring as to a model for the Fury and I received a very helpful response from a gentleman named Brooks. He said if I provided photographs of the speed sensor plug he would produce one. After taking the photos and getting some wiring help from Clueless (never underestimate his helpfulness and knowledge!), Brooks had the info he required and advised that the model specific to the Fury is the H5. Another plus is the price advantage with the SpeedoDRD costing $80 vs $117 for the Speedohealer.
I was impressed with the service, price and upon receiving the unit, installation and programming was also a snap. The speed or VS Sensor is located in front of the rear tire just above the swing arm in front of the right side rubber flap (photo attached). Once you find it, you simply unplug it, install the SpeedoDRP in between the plugs, route the programming wire to a convenient location (I put it by the battery under the left cover) and finally complete the programming. This YouTube video also helped simplify the programming.
I programmed a minus 7.6% and now my speedometer matches my GPS precisely. So if you want to correct your speedometer, I highly recommend 12OClock Labs and the SpeedoDRD.
