If you actually need to replace the VS Sensor the manual does say that you must remove the engine (page 21-15 in my service manual). If you are buying the SpeedoDRD to calibrate your speedometer you only need to unplug the wire coming from the VS Sensor and install the SpeedoDRD between the plugs. This does not require removal of the engine.SG,
not sure what you are pointing out for me....is this where the vs sensor is? I need to change mine but not willing to pay to pull the engine.
Hope this helps
