OK, rode my bike to Hattiesburg (approx 30 miles) at 75 mph at 8:30 am…..bike ran fine, no probs. Had set my fuggin controller back from 4 to 3 in mode 1 (mode for additional amount of fuel added under cruise conditions) and back from 6 to 5 in mode 3 (mode for additional amount of fuel added during full throttle conditions)….left mode 2 (mode for additional amount of fuel added under acceleration) set at 2.
Fuggin’s dyno settings for the fury with fuggin viper2’s for the first 3 modes is 4,2,6 – which is what I had the bike set at. I moved those back to see if I could get better gas mileage.
Anyway…..filled up bike again (overfilled to just beneath tank rim accidentally – gas lever stuck, then freed up and squirted more gas than I wanted) and went 1.2 miles to the staging area. Bike sat in sun for approx 3 hours…..temps were in upper 90’s and probably low 100’s on the asphalt. Got on bike, started it up to wait for procession to begin, idled fine for the approx 12 minute wait. Procession began, I got out of the parking lot and onto the road and the bike was starving for fuel….I’d crack the throttle and it would sound starved….spitted and sputtered and died. I, once again, have had to pull out of a procession because of this. I took the cap off, shook the bike, and other things, out of ignorance in trying to get the bike going….it would start fine, idle good at first, but as soon as you put it in gear and even began throttling, it would die. I finally pushed it to some shade, sat there for about an hour and let the engine cool completely. Fired it up and it ran fine….rode home because there was no way I could catch the procession. (Side note: There was a stock red fury there as well and he drove out of there fine)
This is 3 times this has happened.
Common variables for all three times:
1. Overfilled tank to near rim.
2. bike sat in high heat for hours
The first time this happened, I had not adjusted back the fuggin controller before. Also, I managed to keep it moving and the missing/starvation quit after about 10 minutes, then ran fine for the procession and the 4 hours to return home.
Common variables for last 2 times:
2. Bike sat in heat for hours
3. Had set controller back night before to get better mileage.
4. Had to wait in shade for engine to cool and ran fine after that
This is unacceptable. I haven't pulled the fuel pump to replace filter screen. Looked in the service manual last night and it looks like I'd have to remove the rear tire and shock just to get the pump out
Unlike Richard, I don't have a jack stand.....wonder what it would cost me for the dealer to replace the fuel screen? Clueless????
Met a local dyno guy who said he could dyno my bike (this was before the above). Should I take it to him before I have anything done and have it dynoed? Or would that be pointless if the screen was partially clogged? Why would a clogged screen be an issue? Seems to me that if it were clogged, it would happen more than just when my bike was overfilled and sitting prolonged in the sun????
Guys/Gals, I need help!!!!!!!!!!!!!!!!! Any and all comments/suggestions/ideas would be welcome!
Thanks,
Bob
Thanks,
Bob
