My stealth tailight is flickering on the left side under accelaration. Just wondering If anyone has this same problem. I checked out all the wiring and everything seems fine??
seams to be a bad ground issue arising lately. Talk to Pfiefler85 he had a stealth grounding issue it was in the light itself. he fixed by adding a ground wire to the left sideMy stealth tailight is flickering on the left side under accelaration. Just wondering If anyone has this same problem. I checked out all the wiring and everything seems fine??
Wasn't RAW working on it to fix the problem? I really want to get the stealth light but not if it isn't going to work correctly.seams to be a bad ground issue arising lately. Talk to Pfiefler85 he had a stealth grounding issue it was in the light itself. he fixed by adding a ground wire to the left side
Save yourself a good chunk of change and make your own.Wasn't RAW working on it to fix the problem? I really want to get the stealth light but not if it isn't going to work correctly.
Dare had the same issue, they sent a replacement, but he had a 150. dep till old got returned.Wasn't RAW working on it to fix the problem? I really want to get the stealth light but not if it isn't going to work correctly.
+1.............Save yourself a good chunk of change and make your own.
Damn,time to go thread searching i guess. DIY would be a whole lot cheaper. ThanksSave yourself a good chunk of change and make your own.
Both myself and 2Evil made our own. Both are different, and both offer different but similar results. I think mine cost $65 to make. A lot easier to swallow then 300.Damn,time to go thread searching i guess. DIY would be a whole lot cheaper. Thanks
What you have paid in shipping you could have made your own and not get hastled by the cops.Had the same thing with mine except I think it may have been a short instead of a grounding issue. Just sent it back to have it fixed for the second time. They've been Great to deal with and very helpful but it's still a pain in the neck. Pulled over by the cops twice for it and all the extra shipping charges on top of what I already paid.
inside half of left side is dead on mineWhat you have paid in shipping you could have made your own and not get hastled by the cops.
Or sensible because i wouldnt spend the 300 clams for almost the same thing. Which .... it looks like has bugs of its own and .... they want to charge to to send it back for repairs.CB, calling it a POOR MANS MOD. You took a raw piece of metal, cut and bent it, and formed it with your own hands, and made something of greater value. I would of called it a RICH MANS MOD, because if you do it this way, you will be RICHER!![]()
