1 - 4 of 4 Posts
Anyone found or know someone who is making a steel fender for the Fury?
For rear you are Outa luck right now, For front if you take a look at some of the parts sites you might be able to find one you like that will fit (would possibly have to tweak it a bit where the mount is to get it positioned right about where you want) then would have to drill it for mounting and paint gotta account for size of wheel and width of tire. If you call some places they might be able to help you with getting one that fits nice with the tire and all.
You can also get fender blanks from some places where you can cut your own pattern so you can position it to mount wherever aslong as it properly wraps tire, then you have to cut whatever design you want and bend where you cut for mounting tabs
Yeah, it is more than likely not worth it for my reason. I ride solo 99% of the time, but I have this great passenger seat that is magnetic. It works great on steel fenders (does not move it is so strong) and I do not have to deal with those suction cups that work half the time or leave marks. Obvioulsy this seat won't work on the Fury, so I guess it will just sit in my garage until I get a bike with a steel fender again. Ryguy00, you need a passenger seat?
well you could possibly do the rear, but fitting it would be a pain since the mounts are the 2 pins and its held down mostly by the seat bolts, and it wraps under the seat. I dont know if the Sumo kit has steel fenders but that may be an option for the rear
1 - 4 of 4 Posts
