1 - 20 of 27 Posts
I have a 2018 Fury and love everything about the bike except the factory exhaust.
I can't afford to change out the exhaust plus the fact that the chrome exhaust from the factory is beautiful.
My question is, can the baffles be removed, modified, or "punched out" and give a better sound without causing trouble with the air/gas ratio and setting off the computer?
Thank you in advance for your input. Ride safe friends.
Years ago there was a company that would take the stock muffler, cut it open and gut it then put it back together again. I don't know anyone on the forum who did that. Some folks drilled out the muffler with varying results. (mostly sounded like crap)
The stock US muffler sounds really good with a high flow intake and fuel controller or reflash. I did this to my bike, I removed the stock AU/EU/UK muffler and replaced it with a stock US muffler. My local Honda dealer reckon my bike is the best sounding bike they have heard and they have heard a lot of bikes.
Just a footnote I found the stock US muffler sounds totally different with the stock air cleaner on, so you may like to try a high flow air cleaner before you go hacking into a perfectly good muffler.
@Rope sent me his Cobra slip-ons, they look factory and have what I would consider the best, deepest sound you can get out of a Fury for not a lot of $$$. Loudness is half between stock and straight pipes.
If you find the Fury Throughout The Years thread there's a picture of the muffler system internals, which details why coring isn't a great option vs. buying slip-ons.
Discussion Starter #4
Thank you!
Discussion Starter #5
Thank you!
It was a bit hard to find the post unless one knew what they were looking for, here's the link:
Most people drill the back out, but it's the front cans (in purple) that need to be cored so the plate immediately behind them can be hole-sawed (an extension on a 1/2" high-torque drill is needed). (The rest can stay, it'll be a muted thump at that point.) To un-cork the thump, the exit tube (all the way in back) can be hole-sawed out just slightly larger diameter than the tube, then the whole assembly can be wiggled & twisted out with a needle-nose pliers. This will give a hollowish-bump-thump sound, which is pretty decent. If burrs were created they can generate an unpleasant whistling sound--use a 12" long round file to remove them. Investment: 1 hole saw and about 3 hours; the hole saw teeth will chip/break when breaking through the heavy exhaust plate if there's nothing to keep the saw perfectly centered. Go slow--patience is the key to not tear up the cans. If more is removed than this the sound gets brash, though some people like that--it is, however, hard on the hearing.
I don't like spending money needlessly, so if you want to attempt this no-budget mod, more power to you (a cheap Menard's hole-saw works). I'll casually mention the Cobra Slip-Ons again since they sound awesome, mount easily, and fit great, but the choice is yours, I support you either way.
This guy might support you too, but he looks a bit more like a model and less like a guy who turns a wrench...:
238795
Don't over bake it is my opinion. If you haven't removed the rubber block at the back of the air box, do that first. For the muff I simply drilled out the welsh plug with a stepped counter sink using a hex extension long enough to get the job done. They are quite inexpensive. And then drill 3x3/16 holes around each outlet of the two pipes in the retainer. No mapping required, a good note when passing and you don't wake the neighbourhood when you fire it up. More air in more gas out, you only need mapping when you exceed the computers parameters, not going beserk on one thing is in your favour. Been using this for 2 years with no prob's except a big grin.
Rubber side down and all is good.
2013 Honda Fury VT1300
Not sure which way you're wanting to go with the exhaust but I spent around $60 and made mine. I got 2- 1 3/4" tail pipes from my local parts house and some exhaust wrap. Cut the tail pipes to a slight offset and then cut notches on one end to secure onto the stock pipes. I took the c clamps off the factory muffler and used those to secure it to the stock flanges. I cut the mounting tab off the factory muffler and welded it to both the pipes to hold and support it and bolted back down to the stock location. Sounds great but I do need to buy the valve delete plates so the popping will stop but learned to adapt to that by letting off the throttle earlier when slowing down.
238859
238857
238858
Couple of things, so as not to confuse our Canadian and American brothers. The US air box does not have the rubber plug and the US muffler is quite different to the AU/EU/UK one so the drilling instructions won't align. I did a post on the difference. I also replaced my stock AU muffler with a stock US one and it sounds way way better than the AU/EU/UK version.
238862
238863
you can get the stock exhaust heat shields back over it. ill send photos when i get home of mine, i did the same thing $30 for pipes a couple i had laying around for an balancing tube for both exhausts and then the fiberglass wrap. i did the same thing as you for assembly, just made a tab in back for the bolts to attach for the heat shield.
cant tell from the photos but i welded a pipe in between the two so that it can balance a little more within the exhaust. i dont seem to get too much popping at all but im still looking to do the pair valve deletion.
Discussion Starter #11
Thanks all for some great ideas! I am so far enjoying riding my Fury, even the last couple of days here in Florida with the temps around 43* in the am!
I think first and foremost I'm gonna research for a windshield as it would have helped cut that cold air the last few days, and we here in Florida twice a year face the "lovebug" season and I don't want to be face covered with them after a ride! Think I saw people on here promoting a particular windshield that kept the look of the Fury but did its job blocking excess wind, bugs, and even some of the rain at times. Can't remember the make or model of the windshield? Any advice?
As always, thanks guys and gals, and safe riding!
Memphis Shade's 'Demon' windshield, I believe is what you are referring to.
Discussion Starter #13
Hi Gizmo,
Well, been searching the windshield you suggested and so far came up empty.
I've never bought a bike before that didn't already come with a windshield attached so this is new to me.
From what I have seen the Demon attaches at the handlebar, is that correct?
Also is that safe, as I believe all my past bikes had the windshield attached to the forks with quick release for the option of riding with or without?
Some of the Demons I saw were called low profile and I had to buy a separate mounting kit which costs more then the windshield.
Do you or anyone else on the forum actually have one installed on their bike and can tell me the exact model # and place they bought it at? I certainly
would appreciate any and all help I can get!
Thanks guys, and safe riding!
Hi Gizmo,
Look up Memphis Shade on the Internet and look at the Speed Demon model of windshield. It DOES attach to the forks and the attaching hardware with a quick release and IS separate from the windshield to buy because of the various motorcycles that the windshield fits AND IT IS more expensive than the windshield. I also see that the Speed Demon can be purchased to be mounted on the handle bars too. I have the fork mounted one on my bike and it looks good. J & P Cycle (where I bought mine) is about 80 miles from me in Florida.
Discussion Starter #17
Hey guys, Happy New Year!
I haven't done any changes to my bike as yet, just riding when I can.
I'd like to follow up with the idea of the Cobra slipons, but I don't know what that entails. Could someone explain to me how that works and what has to be done. It sounds like my stock exhaust stays mounted but part comes off and the slipons replace a portion of the exhaust, if that is correct?
Also, I have 900 miles on my bike now, am I due an oil change, the dealership changed the oil on my purchase several months ago when the bike had only 54 miles on it?
As always thanks guys, I hope everyone is healthy, happy, and enjoying our Fury's! Bill C
Rock Stock 2019 ABS
Yes you're late! Get your break-in service done ASAP!
Oil change, valve check/adjust, check idle, brakes, clutch, fasteners, steering head, all at 600 mi.
All oil changes are important but that first one at 600 miles is paramount, and the one they did at 54 miles doesn't cover the need.
You just remove the muffler and replace it with the slip-ons. The header pipes stay as they are.
1 - 20 of 27 Posts
