Yea, soft plastic tails.. They are a metal fender frame with a hard molded fender.Are these ....furys "softtails???????or fill me in if you would.
Technically "Softail" is an HD trademark, they are kind of backwards to this as the shocks are underneath the bike and work opposite of a standard shock, compression is when the softail shock is being pulled apart. This is a mono shock type set up.Are these ....furys "softtails???????or fill me in if you would.
Not yet, but wait till L&M comes out with their air shock. It sounds like it will be priced reasonably.Is anyone out there offering a shorter stiff spring as an inexpensive way to lower the fury? I'm not sure how much the Low and Mean air ride will be but I assume that a new shock and spring set up would be less.
