OK just so we are clear I am not blaming anyone for anything in this thread. This is meant to be completely informative as well as help me gain some insight into my solutions.
I have the following modification done to the rear end of my motorcycle.
T-Mod - Dropped it 1.5in
L & M Lowering Spring - Turned all the way up to the highest level
Ginz Sissy Bar Setup - which attach's to the frame under the fender and then comes out to set up the sissy bar
On my way out of the driveway tonight I heard a slight rubbing, I reached under the fender and pulled rubber from the tire out of the right side of the sissy bar setup.
My tire now has a 1/8 in gouge in the wall of the tire going all the way around.
My question is:
If I put the stock spring back on it will it elleviate the problem by raising the frame or do I have to remove the sissy bar all together because the T-mod lowered the frame to much and now there is not enough clearance for the Sissy bar setup.
I know no one has dealt with an issue like this before but guestimation would be helpful. It looks like I am either going to be selling a lowering spring or a sissy bar on here real soon.
My question is:
