hello I have a honda fury and I am interested in getting the same type of tail lights like this one .I wont to know if it is a bought kit or it's remade from the original
Yeah it's a self done mod where you cut off the oem license plate bracket, you can do it like he done or you can just dremel it off without needing to fill the whole in like a lot of others did, but with that being said you will have to find another place to move the license plate to, i.e. a side mounted license plate bracket.
Also you can contact MyFuryRide as he does a mod to the tail light assembly where he cuts off the license plate bracket and puts the turn signals inside where the brake lights are, and he can also put a license plate bracket underneath the run/brake/turn signal light that looks better than stock and doesn't hang as low, just send him a pm and ask him if he has any or can make you one, I believe he sells them still and then you send him your oem one.
