1 - 4 of 4 Posts
Ok i want to paint My speedo and since I don't have my service manual yet can someone tell me how to take this thing apart ? Thanx...
Removal/installation: Remove the socket bolts, fixing clips and speedometer rear cover. Remove the socket bolt and speedometer front lower cover. Remove the dust cover and disconnect the speedometer 20P (Gray) connector. Remove the following:
Screws,
Washers,
Grommets,
Speedometer.
Installation is in reverse order of removal.
Disassembly:
Remove the screvs and upper cover. Remove the screws and under case. Remove the circuit assembly from the upper case.
Assembly is in the reverse order of disassembly.
Discussion Starter #4
cool thanx got it apart ... I didn't want to do it without a little input . Thanx guys ....
1 - 4 of 4 Posts
