Well if that's the case fuggin was using accutronix as well as low and mean. Because they both had the same set up neither was listed as accutronix from my knowledge. You have the cover only on order ? If so how much ? What's the part number so I can look it up ? If it does not work for you be careful making returns to them.I maybe wrong as i am learning here but I believe accutronix is the only one that will work with your set-up I have one on order from [email protected] Cycles
