Anyone here use Dyna Beads? I ordered the 2oz and 1oz bags but have not had time to put it in my tires to see how well it works.
To ditch the big ugly weight hanging off the front tireI have them on my C, put them in when I got the Metslers, seam to work great, i also don't know why you need them on a new bike tho
Once in a while you will find a tire/wheel, that do not need any weight added, I did a Goldwing the other day I took off 20 (grams) from the old tire and the new one did not need any, I had to check it 3 times to make sure. If you are not feeling any vibrations i would not worry.I just looked at my tires and could not see the Balance weights on the front or the back. but it has no vibration. just would like to know if any one else missing the Balancers
Remove them, if your worried, put a small piece of tape to mark where they are (in case you have to put them back on, I am sure you won't), pop them off, go for a test ride, you do not need the weights and the beads. I can usually pull them off by hand, but be careful that you don't scratch the wheel.Well I got the beads in today and about 150 mile... I have to admit they did cut back on some [not all] of the fine vibration in the bike. My right hand did not numb out on me once during the ride and my left mirror seemed more clear when cruising.
I think the instructions said to remove the tire weights.... I left them on... should I remove them? I would hate for it to go all out of wack.
Not a miracle cure, but indeed noticeable.
