1 - 7 of 7 Posts
Like any side mounted license plate, you need to tie into the factory license plate wiring. I chose to heat shrink the wires, run them in a plastic flex tubing under the fender to use the factory connector in the rear fender.
To diguise the wires coming from the license plate, get some sticky wire holders (clips) to place under the rear drive swing arm.
(I got a pack of ten from ACE hardware)
This will allow to hold the wires up and out of the way.
Hope that helps
I was thinking about ordering one of these my only question is where do you run the wire for the tag light thanks for any help
I took the fender and such off and used the stock wires. I also tookj the old plate and light off the back area too. I will try to get a picture or two for you. I did not google where ya live but i am in North tampa if you are down this way.
Stan
1 - 7 of 7 Posts
