Hey it fits fine but it's definetly angled back more. I'm in the process of getting a custom tall sissy Bar and pad made for my wife. Check out Ginz Choppers, they do 1 off work.Do you have any issues with the passanger seat? My wife loves to ride so if the passanger seat doesn't quite fit back properly I'm SOL.
How bad is the angle? Does the wife/GF really notice a lot of difference? This is my only hang up of doing the mod. All I need is to give my wife another reason to bitch at me....LOLHey it fits fine but it's definetly angled back more. I'm in the process of getting a custom tall sissy Bar and pad made for my wife. Check out Ginz Choppers, they do 1 off work.
Please post pics of your sissy bar when you get it. I am having a hard time figuring out a way to not drill holes in my fender. I also don't know how tall I want to go.Hey it fits fine but it's definetly angled back more. I'm in the process of getting a custom tall sissy Bar and pad made for my wife. Check out Ginz Choppers, they do 1 off work.
Have you made sure that your shock is fully adjusted to the "HI" position. Also, your pre-dampening probably needs to be adjusted to stiffer rather than the softer that we are used to, to support the weight better and to stop the "rubbing".I did the tony mod and now the rear tire rubs with my wife on but together its around 400lbs on the bike. So, she was not to happy with me that day at all, so tomorrow I pick up a 2008 street glide cruiser, this will allow me to have my solo bike I wanted.
How much did you end up cutting out of the frame?i did the tony mod and now the rear tire rubs with my wife on but together its arournd 400lbs on the bike. so she was not to happy with me that day so tomarrow i pic up a 2008 street glide. as are cruzer so now i have my solo bike i wanted.
Something doesn't seem right. How much of a cut did you make in it when you did the mod and how much clearance do you have now from the inner rear tail where your license plate light is when the the bike is sitting with no load on it? This would be the only area you would be rubbing and not on the top. I made a cut thats about as aggresive as one could get leaving less than an inch clearance in this area and had initial rubbing but a quick shock adjustment took care of it nicely. You would be surprised how nice the bike rides once you crank in and stiffen up the shock adjustment. I would even suggest this shock adjustment to all with or without the mod. I was surprised and like the new shock adjustment much better than the old stock position.i did the tony mod and now the rear tire rubs with my wife on but together its arournd 400lbs on the bike. so she was not to happy with me that day so tomarrow i pic up a 2008 street glide. as are cruzer so now i have my solo bike i wanted.
Are you saying to crank it up to Hi or Low?Something doesn't seem right. How much of a cut did you make in it when you did the mod and how much clearance do you have now from the inner rear tail where your license plate light is when the the bike is sitting with no load on it? This would be the only area you would be rubbing and not on the top. I made a cut thats about as aggresive as one could get leaving less than an inch clearance in this area and had initial rubbing but a quick shock adjustment took care of it nicely. You would be surprised how nice the bike rides once you crank in and stiffen up the shock adjustment. I would even suggest this shock adjustment to all with or without the mod. I was surprised and like the new shock adjustment much better than the old stock position.
Dave, are you talking about adjusting the "rebound damping", or the "spring preload", or both? May be a stupid question, but I've never messed with my shock and I would like to improve the ride. The bumps have always killed me.Yes crank the knob in to stiffen the shock up for a harder and stiffer ride. I had never previously played much with this adjustment setting before but I had no choice once the mod. was done to get away from the rubbing issue. The bike now actually takes a bump better and appears to just skip over the bump now instead of absorbing it while moving me around. I feel like a flat stone skipping across a pond and I don't even notice the small bumps anymore . I know every ones adjustment may be a little different according to you weight and personal comfort but It only takes a few seconds to play with the adjustment yourself and you may also find a much better adjustment setting for yourself than the stock setting.
Yea, agreed... figured this out when I got the L&M spring... it feels much smoother in the higher positions... just have to imagine the type of bumps you may take and account for that, and it tends to turn out pretty good as far as dampening goes... I raise it up when my girl rides and lower it to almost the bottom when I ride alone. Makes a world of difference. Thank goodness for that hand crank, no puns intended of courseYes crank the knob in to stiffen the shock up for a harder and stiffer ride. I had never previously played much with this adjustment setting before but I had no choice once the mod. was done to get away from the rubbing issue. The bike now actually takes a bump better and appears to just skip over the bump now instead of absorbing it while moving me around. I feel like a flat stone skipping across a pond and I don't even notice the small bumps anymore . I know every ones adjustment may be a little different according to you weight and personal comfort but It only takes a few seconds to play with the adjustment yourself and you may also find a much better adjustment setting for yourself than the stock setting.
CBISMONSEZ, your ride has come a long way and is really looking sweet. I'm really feeling the taste of it. Nice job!im aslo gonna add that since the fender sits lower, so does the seat. Im sitting low enough now inside the bike that i can see in my mirrors without ducking down like i used to. Lower center of gravity is a good thing.
