1 - 10 of 10 Posts
I have been looking for about half hr and can't find either. At least not for the fury. I know they exist. Can someone tell me where to get them please?
Discussion Starter · #4 ·
Didn't think about that. Plus I am not doing the install. Where would be the best spot for it?
I believe the reservior cover for the VTX 1800 fits the Fury.
There are about 101+ places to relocate your horn, here is 1 of them. On Predators bike, I mounted the horn under the rear fender. In front of the tire, under the swing arm pivot, you will see a cylindrical charcoal canister. This canister is attached with two 6mm bolts. Loosen the big nut on the back of the horn so you can re-clock the mounting bracket. Bolt the horn to one of the canisters bolts, tighten the horn nut, lengthen the horn wires & route them to the horn following the stock harness. If everything is mounted correctly your horn will be as loud as factory & out of sight, & pointed so it will not fill up with water.
Hope this helps,
Troy
Discussion Starter · #10 · (Edited)
Used snuffdog76's link
and asked if the reservior cover for the 1800 would fit the fury and they said it is the same.
Thanks guys.
Thanks for the offer snuff. I always like to buy new if I can.
1 - 10 of 10 Posts
