Ok so I just googled this because I haven't heard of 4" extenders but it came up on my search for VTX 1300 . I am almost willing to bet 10* trees are coming out to accommodate these 4" extenders already on the market . Could be wrong though ...4 inches? Don't do it .....3 is the maximum and i wouldn't even do that without the trees. It'll raise the front end up wayyy to much and won't look right.
As far as the warranty goes, you'll be fine.
10* trees are to dangerous for the stock neck angle on the fury. The way I understand it you have to have a larger front tire or a neck rake to gain enough trail to handle 10* trees and still have safe trail #'s but......................................I am almost willing to bet 10* trees are coming out to accommodate these 4" extenders already on the market . Could be wrong though ...
Better hold on with 10* trees. Im sure its very unstable with those. I could be wrong but I dont think so. Better hold on tight either way lol10* trees are to dangerous for the stock neck angle on the fury. The way I understand it you have to have a larger front tire or a neck rake to gain enough trail to handle 10* trees and still have safe trail #'s but......................................![]()
8's & 3'' & your an idol?I have the scootworks and the 8's with three inch extenders. From what I remember my warranty was good because I had honda do the work. I thought they said that was the only reason it was still good. You could call your local Honda shop.
I hope your raking that bitch out or your front end is gonna be about 10" off the ground![]()
Of course it helps because you have lined there pockets with money from installing stuff for you, plus they are the ones that telling Honda whether it was a warrantied repair or not so the more you spend there I'm sure the more it helps.My Honda shop said it 'helps' if they did the install in a warranty dispute. I asked when they did my 8* trees and 3" xtndrs. They also said this was not a mod that voids warranty.
