I'm looking at buying a Webslinger Speedo Face but would like to find out first what it's like at night? Can anyone who has one fitted tell me if the illumination the same as the original speedo face? Cheers
"shade the numbers"?Tell him to shade the numbers he knows what to do so you can see it.
Thanks for that. I'll make sure that I ask for that to be done when I order it. Did you have any trouble recalibrating the speedo (getting the needle in the right place after it all went back together)?per RSS
Yea, this one is the one he helped me out with... The numbers are key, have to have some kind of shadowing around it. The first one I got, did not have shadowing and it was harder to see the numbers at night, just an FYI.
Thanks again for the info. Doesn't sound hard, just fiddly I guess. I look forward to the link if you can find it (I did a search for Stpete but couldn't find anything). CheersI had some trouble getting the needle back in took me more tries then most I think somewhere around 7 times to get it perfect but after the first time popping off the needle it comes off really easy. My trouble was I kept turning it popping it off so I was really off a couple times. But its really easy just when you push the fork under only go halfway under it Stpete did a really nice write up on it, I will post a link to it.
That looks great! Thanks for the pics. Did you ask Webslinger to "shade the numbers" or is that just how they come normally?Here's what mine looks like w/out illumination, and with. Hope it helps ya
Thanks again! CheersNope, I didn't ask him to shade the numbers, that's just how it turned out.
That's not a bad recommendation. Are you on commission? LOLJust one more note....you won't find anyone better to work with than Webslinger. He is an excellent vendor, you won't be disappointed!
He truly is a great vendor, no B.S and quick service. Will work to make you happy.That's not a bad recommendation. Are you on commission? LOL
That's Excellent. It will make the whole job a LOT less stressful. Thanks!
