trees
There is none in the trees from what I can see! The neck rake is 38 degrees and the trail is 3.5 inches. For proper trail I know you can't go lower than 2.5 inches. I think max without doing any harm would be a 3 deg. rake in the trees with a two over front end. If anymore you would have to drop the rear to accomplish proper trail. They don't make a 45 mm tube. Not for Honda anyway. I know I've been looking! I would like to stretch my Fury out make it more of a pro-street instead of a chopper cause the neck isn't as high as I would like it.
This is incorrect, sorry. There
is rake in the trees, I'm thinking the total fork angle is 38 deg.
I am not positive but it looks like about 5 deg. in the trees.
This would make sence w/ the 3.5 trail
3.5 trail is not any too much trail at all on a bike that heavy. too short of a trail is very spooky and should not be taken lightly. The standard vtx's have almost 6 inches if trail, yes they feel heavy compaired to the Fury, but that is what is making the fury so nutral in the turns.
I have thought about doing trees that are the same geomitry as stock, just cleaner looking. I have also thought about backing them up a little (3 deg.??)and giving the bike a little more trail, raising the neck a little.
My thought if someone want's trees is do the math and go to a 23 in front wheel, and maybe lengthen the trail just a bit also.
I will welcome some input here
