1 - 5 of 5 Posts
I'm thinking of putting 12in ape hangers on my bike? I know I'll need to buy longer lines but I'm unsure where to buy them. Any ideas?
Also will I need to buy a new speedometer or can I still attach the original one?
Not sure where you are in USA,
As you know you will need to have the throttle and clutch cables custom made, Also the front brake line/s (ABS ?).
I have just raised my bars by around 4 inches and had to measure up the cables after the bars were raised. I sent my OEM cables to be copied and made longer to a custom manufacturer here in UK.
As for the speedo' Unless you had the apehangers custom made for the speedo to fit back on them,,,,,,,,then no you will have to re position it.
I got mine from Barnett. Also had them make a 6" longer front brake line. Nice folks to work with. Took 3-4 weeks. Should be less time if you are just doing cables.
1 - 5 of 5 Posts
