If it dose I can't how Please help
Chrome Billet License Plate Bracket and Side Mount Taillight for Harley-Davidson
Impressive!, except it's set-up to mount on the right side; you need one that mounts on the left side. I guess you could drill some new screw-holes, and that would move it over................If it dose I can't how Please help
Easier just to mount it upside down (brake light on the bottom) and flip the bracket (though you'll see the wire channel as it will be on top). Your biggest issue is that the mount is way too thick, the axle is not long enough. You'll have to machine it down a bit.Impressive!, except it's set-up to mount on the right side; you need one that mounts on the left side. I guess you could drill some new screw-holes, and that would move it over................
Which will, probably, weaken it too much and it will vibrate too much and, eventually, crack and fall off. Need some provision for the Axle Cinch-Bolt to stiffen the whole thing..................Your biggest issue is that the mount is way too thick, the axle is not long enough. You'll have to machine it down a bit........
I was going to mount it upside down but like you said the mount is way too thick. Has anybody seen something with bright light?Easier just to mount it upside down (brake light on the bottom) and flip the bracket (though you'll see the wire channel as it will be on top). Your biggest issue is that the mount is way too thick, the axle is not long enough. You'll have to machine it down a bit.
now, that's more like it.
