Right side turn is blue, running light is blue/white trcerGot some new lights for turns signals and need the wire diagram for the install. I need to know which wires are for turn, run, ground. I tried a search, but couldnt find it.
True, but Honda hasn't changed the color code on the lights for at least the last 3 decades. It is the 1 constant in Hondas changes..Color codes are helpful in locating wires in a large connector or harness but it is always wise to verify with a test light which only takes a minute or two. Not much fun having to re-solder connections just because you misinterpreted similar color codes or the factory made a change to the bike color codes on one or two wires shown differently in the manual
I looked at my VTX, it has the Kury led bullets (my Fury has the t/s in the mirrors and THEY are the ones with the circuit in them ) my lights are hooked up just like yours, and they all (run and turn ) work, if neither side is working I would suspect a bad ground, did you hook both Kury black leads to the same ground ? If so I would jumper a lead from the black to a known good ground (touch it to the forks or the steering lock, or a bare bolt on the frame) and see if they come on.Headlight turns on with the key in the "on" position, horn works also. Wires are soldered together, tried to hook up 9v battery lead, light doesnt come on. pull bulb, connected to battery, it works. Could the circuit in the housing be bad?
LMAO! Had a flash-back; reminds me of my days in the business (way back in the last century) when we'd tell 'em, "Hey, I can't overhaul it over the phone!". LOL.I looked at my VTX, it has the Kury led bullets (my Fury has the t/s in the mirrors and THEY are the ones with the circuit in them ) my lights are hooked up just like yours, and they all (run and turn ) work, if neither side is working I would suspect a bad ground, did you hook both Kury black leads to the same ground ? If so I would jumper a lead from the black to a known good ground (touch it to the forks or the steering lock, or a bare bolt on the frame) and see if they come on.
NMUCat:Got some new lights for turns signals and need the wire diagram for the install. I need to know which wires are for turn, run, ground. I tried a search, but couldnt find it.
He Said :NMUCat:
You should pick up the Fury Service Manual..
A complete fold out wiring diagram is provided in the back for both the California type and 49 States/Canada models
But beside that, it has details on everything to remove and replace on the Fury..
Nice manual to have..
T
So NMU did you get it fixed ??Sorry my service book has not arrived yet.
