has anyone tied into the wiring on the taillight for an aftermarket plate relocator kit?? I need to know what wires to tie into. Thanks in advance
On my video, I showed about where I tied into them for the side mounted plate that I have, but the actual colors of the wires, couldn't tell ya. I dug into the wire loom and then located a couple of wires, then I proceeded to start tugging lightly on all the wires till I found the right two wires, then rerouted them via the swing arm and underneath it....has anyone tied into the wiring on the taillight for an aftermarket plate relocator kit?? I need to know what wires to tie into. Thanks in advance
You can tag into any of the two brown wire for running light in the rear. You should find two of them back there. One for license plate and or one is for the running light side of the tail light.The yellow and green is the stop light side.. Light blue is right directional and orange is left directional and of coarse your green is for your ground.has anyone tied into the wiring on the taillight for an aftermarket plate relocator kit?? I need to know what wires to tie into. Thanks in advance
Photo...Remove the rear fender, at the rear of the frame is a black boot, inside the boot are 3 connectors 1 orange, 1 blue, 1 white, that one (white) is (are ?) the wires to the lic plate, a brown wire (hot) and a green (ground)
Ah, it's the white one that does the light on the back, the small white connector. The orange and blue are for the turn signal lights and the big black sleeve, under there is where the main connector harness is for the brake lights. Needed something to jolt my memory, thanks Tony.Photo...
LOL.....Mr. Peabody......Did you really have to regurgitate that?
Oh my bad, your working on 3 gazillion post now..
By the way it was Clueless that provided the detail.. I just helped with the pic..
You need to change your name from RSS to Mr. Peabody..
Well now that's just rude....... No, sorry... didn't see you guy's agreeing on the wires from the earlier posts...
But, here you go... here's both of your guy's sign:
Take the rear fender off. On top of the factory tail light you will find plugs for the tail light, turn signals, & license plate light. IMHO this would be the best place to plug in your new taillight or side mounted license plate light.has anyone tied into the wiring on the taillight for an aftermarket plate relocator kit?? I need to know what wires to tie into. Thanks in advance
White wire?? My license plate wire is a brown wire same as the tail light wire and its listed in my service manual as brown. Whatever!...... No, sorry... didn't see you guy's agreeing on the wires from the earlier posts...
Bah, would've worked if I didn't re-read my post Dave... goober...White wire?? My license plate wire is a brown wire same as the tail light wire and its listed in my service manual as brown. Whatever!
