Just installed the CRP on my 10 fury. Went in fine but it seems so loose. I had it working fine earlier today, Went in gear fine, then I saw that the bar was right next to the engine so I moved the bar to that position, now the lever is all play and it wont go in gear or bucks then stalls. If I have a gap, there is some tension on the lever but not much and I am not sure if that is correct since it was tight before the install. I tried putting the nut at the lever all of the way in, and out and that did not do much. If I have some gap there is some tension but now the bike still bucks a bit.
