Let's show off our white Fury's
18K views 51 replies 29 participants last post by  hottubhank
#1 ·
I'll start 2014 red frame white skins
Sent from my iPhone using Tapatalk
#3 ·
Guess I better get in on the action.
This is Marilyn, named after Marilyn Monroe.
I named her that because she is Sexy as Hell and black & white like most of the pics of the bomb shell.
Mod list:
Worlds first ECU reflashed Fury
Flash specs: 700rpm idle/6500rpm rev limit/205° cooling fan
Black powder coated 8° triple trees with 4" fork extensions
Front fender relocation brackets built by me
Gar's factory forward control mod blacked out
K&N air filter w/ modified air box
Blacked out engine with polished fins by me
Blacked out head covers on engine
Black chrome clutch/timing covers
Custom 2 into 1 pipes built locally and wrapped by me (soon to be re wrapped)
Modified stock seat and reworked stock sissy bar so no holes drilled into fender
Home made "Platinum" air ride kit with upgraded compressor and air tank underneath for instant up capabilities and quick disconnect for air hose to air up tires.
De beavered rear with LED stop/tail/turn
Side mount tag bracket with additional brake light built by me
6000K HID headlight inside a crystal clear diamond back housing
Pair valve block off plates built by me
EarthX lithium iron phospate battery rated at 640cca so no hot start problem
Custom skull speedometer face plate
Soon to be BIG/linked brake upgrade from the ABS Fury (have the parts now I need the time).
De-stickered de-badged de-reflectors
Masonic emblems covering the Honda logos on both sides of the engine
Matching white headlight bucket
LED front turn signals mounted under the lower triple tree
Relocated ignition switch/key to the right side where it should have been to start with IMO.
Probably something I am forgetting... Lol
#16 ·
Oh WOW ! Your bike is having two shadows .
At least, I'm seeing two dark bikelike shapes in the background . . . . :wink:
#24 ·
I'm fairly new to the forum as well and bumped into this thread. Here's my white white stallion! Glad to see some good looking Furys out there.
You need to be extra cautious on this thread. Since it is a well known fact that white Furys are the fastest, the reflector police keep a close eye on this thread, and you Sir appear to NOT be in compliance with the law.
#36 ·
Hey Gunshow, that is a unique treatment you did to your bike. Looks real nice. You've got a close of one of the panels that you painted or covered ?
Can't really make up what you did to it :grin:
#37 ·
I'm not a huge chrome guy, so I wanted to color match the bike. Once I saw the hefty price tag on the pearl white paint I decided if I'm gonna spend some coin, make it something I haven't seen before. So u went with a white carbon hydrodip with a black fade. From far the carbon layer gives it that white pearl look, but up close you can tell it's not something from the factory
